Hose on air box (size and replacement)
Posted: Fri Jun 26, 2020 8:38 am
by Lukeh17
Hi,
What is the small tubing called circled in the picture? Also, the rubber hose at the end which connects to the airbox unit is perishing and I was wondering what size it was and where I could buy a replacement?
Re: Hose on air box (size and replacement)
Posted: Fri Jun 26, 2020 3:38 pm
by unknownmale
It's just a vacuum hose. Any 3mm vacuum hose will be fine, just cut to fit - https://www.amazon.co.uk/sourcing-map-S ... uage=en_GB
Posted: Fri Jun 26, 2020 4:16 pm
by Lukeh17
unknownmale wrote: Fri Jun 26, 2020 3:38 pm It's just a vacuum hose. Any 3mm vacuum hose will be fine, just cut to fit - https://www.amazon.co.uk/sourcing-map-S ... uage=en_GB
Fantastic. Thanks a lot
Posted: Thu Jul 02, 2020 10:02 am
by Eagle1
I use silicon hose and have also replaced all the hoses on the carb.
Posted: Mon Jul 06, 2020 9:05 am
by Lukeh17
Yeah, I bought the one you recommended and it's fitted. All good so far!
