White striped tail lights scala
Posted: Thu Mar 19, 2020 1:20 pm
by Philcraig
I have an 89 scala but the tail lights are normal.
I was after a set with the white stripes across them. They look so much better than normal ones
Does anyone have any for sale or know where I can buy them?
I’ve tried the usual places, vw heritage etc but no luck.
Any help appreciated. Thanks
Re: White striped tail lights scala
Posted: Thu Mar 19, 2020 5:15 pm
by essextom
most these days are worn or a stupid amount of money, might be best to get some vinyl pin striping and sticker new stripes on.
Posted: Thu Mar 19, 2020 6:14 pm
by mr.brown
^^That, or if you are confident, an oil based thick nibbed white paint pen will do the job.
Posted: Fri Mar 20, 2020 8:14 pm
by Vic
I used to buy a liquid mask when I made 1/24 model kits. It would prevent over painting. Otherwise measure the gap and see if there is any pinstriping or such that will fit.
Posted: Sat Mar 21, 2020 10:53 am
by RoccoJimbo
3mm pinstriping works well.
Either pinstripe the raised ridges with preferred colour or pinstripe recesses & spray/tint raised areas of lenses after masking surrounding area. then remove pinstriping after spraying.
