K reg 1992 MK2 GT2 Clutch spec
Posted: Wed Jan 15, 2020 2:08 pm
by Jimbog
Hi All,
I am putting a new clutch in at the weekend and I am confused between 200mm and 210mm clutch sizes. My car is a late 1992 K reg GT2 right hand drive 1800 8v carb EX engine. Any help? I am 90% sure it is the 210mm size. I am also changin the clutch cable and am going for the 1600mm length as opposed to the 1400mm length. Any issues with this?
Jimmy
Re: K reg 1992 MK2 GT2 Clutch spec
Posted: Wed Jan 15, 2020 6:57 pm
by mr.brown
210mm clutch. Be careful as there are variations even in the 210mm - small spline for 8v and large spline for 16v.
I've used different length cables in my mk1 without issue but couldn't tell you what lengths offhand.
Posted: Thu Jan 16, 2020 10:08 am
by Jimbog
Thanks Mr Brown.
Posted: Sat Jan 18, 2020 6:55 am
by james butler
put the friction disk onto the input shaft and make sure it fits as long as that allright you cant be far wrong.
make sure you put a small amount of locktite on the bolts that go through the pressure plate into the crank though you really dont want those coming loose.
Posted: Sat Jan 18, 2020 11:15 pm
When you have the gearbox off it’s worth checking the input shaft seal etc. Good site for info and how to’s...
http://brokevw.com/
A gearbox oil change is always worth it as well if the gearbox oil has done anymore than 50,000 miles.
Posted: Wed Jan 22, 2020 11:13 am
by Jimbog
Ok thanks all. Appreciated.
