Brake servo relocation to drivers side
Posted: Tue Dec 10, 2019 12:45 pm
Hi
I posted a cpl of pics on a thread of how i relocated my brake servo and was asked for more info on how it was done so here goes, firstly this is more for info on how i achieved the physical fit without having to hack large chunks of bulkhead and inner wing / chassis rail away and not so much about what is the best braking component combinations, I can only comment on my set up which works very well and is a massive improvement over the standard set up, I just spent 3 years doing a resto mod on my mk1 (will start a build thread) and when considering the brakes had always planned on upgrading and curing the vague feel aside from binning the ugly look of the linkage bar set up, although there are slight bulkhead differences this should apply roughly for all the mk1/2 scirocco, mk1 golf/caddy etc models so I did the bulkhead mods prior to paint obviously.
One important fact to note is that I’m running a hydraulic clutch set up to O2J gearbox so don’t need to utilise the old clutch cable hole, you know, the one that always fails and pulls through the bulkhead so this had also been deleted/welded up but I reckon it could be retained and just have enough clearance, especially if the Diesel cable with the angled entry is used.
Also goes without saying, this is not a 5 min job and requires some specialist tools that not everyone may have access to, one for the modders out there !, please don't go chopping your car and brakes apart unless you're confident in your ability.
My set up is
Polo 6n2 8” servo
T4 25.4mm master cylinder
Original round vw fluid reservoir
Wilwood brake bias valve mounted on servo (car never previously had a proportioning valve fitted).
New Copper Nickel lines throughout.
Hel braided hoses front and rear.
Wilwood calipers up front with mk2 Golf 16v 256mm Black diamond discs, Wilwood pads.
Polo rear hubs (sealed bearings), Polo rear calipers and Black diamond discs.
Raised rear hub mounts allowing handbrake cable relocation inside subframe
I started by sourcing a decent quality servo and opted for the polo 6n2 one here, part number 6N2 614 100J as fitted to polo Gti’s and others, this is an 8” servo, not the 9” mk2 golf size but more than up to the job and the slightly smaller size over the Golf one helps massively with clearance, these go for around £20 and are readily available, it’s ball operated rather than clevis pin arrangement but can be modded to suit without too much faf,( see pics).
The servo should come with a bracket on the reverse that can be used later in the mod (pedal side of bulkhead) so don’t bin it, unbolt the bracket and use a cutter or grinder to square it off, retaining the 4 mounting holes (see pics).
Unbolt all your old brake lines/servo and linkage arrangement and cut off the front of the heavy block that your servo bolted onto, cut about 10mm down from the mounting face as in pics, this will be used for the polo servo to mount onto, engine side of bulkhead, then cut off the bracing section from bulkhead to inner wing.
My set up is
Polo 6n2 8” servo
