SFQ - The Clock has stopped!
Bernard
Post by Bernard »
My dashboard clock has stopped!
It says 0:06 and has done for a while.
The : in the middle no longer flashes and neither of the adjuster 'buttons' has any effect on the display
Pressing them both simultaneously doesn't do anything either.
I have noticed that the speedometer is no longer illuminated, although the tacho still lights up.
It is quite bizarre,
Could the failed bulbs? be related to the stopped clock?
Is this a common failure?
Has anyone scene it before?
Thanks in anticipation.
unknownmale
Re: SFQ - The Clock has stopped!
Post by unknownmale »
The bulbs in the back of the cluster burn out yeah. and the clock LCD can be replaced
You could try the old IT fix.... switch it off and on again... disconnect the battery for a couple of mins and see if that clears the clock.
Bernard
Post by Bernard »
unknownmale wrote: Wed Nov 06, 2019 7:26 pm The bulbs in the back of the cluster burn out yeah. and the clock LCD can be replaced
Excellent, any idea where to get a clock from if this;
mark1gls wrote: Wed Nov 06, 2019 7:30 pm You could try the old IT fix.... switch it off and on again... disconnect the battery for a couple of mins and see if that clears the clock.
Possibly the best solution I've ever read on here.
unknownmale
Google t3 camper lcd and you'll get a bunch of results...Same screen
GT_II
Post by GT_II »
Presumably though it's not the lcd that's failed, but a problem with the circuit board behind.
