HELP rocco wont start and need it ASAP
scirocco_ne
Re: HELP rocco wont start and need it ASAP
Post by scirocco_ne »
mark1gls wrote: Sat Jun 22, 2019 12:15 am What did you use to get the CO reading, a Gunson home kit or a proper CO machine like they use for an MOT?
Our gunson bud. They wander readings wise but it does seem consistent once you learn how to use it.
Yes I use a Gunson and find they are out around 0.5% compared to the MOT test, maybe try it at 3% to see if it runs any better but mixture is the last thing to mess with so make sure the timing is spot on before adjusting the mixture.
scirocco_ne
mark1gls wrote: Sat Jun 22, 2019 2:26 pm Yes I use a Gunson and find they are out around 0.5% compared to the MOT test, maybe try it at 3% to see if it runs any better but mixture is the last thing to mess with so make sure the timing is spot on before adjusting the mixture.
When i get a chance i am going to get ours cross referenced against a good mot test unit.
I want a mot tester unit myself one day as they can be unlocked from mot format so to speak and be turned into a analyser.
Apparently the manufacturers charge about £150 to do it so its about finding a old unit for the right money. A local classic specialist did it near me.
I find with this Gunson its best to use it after 10 minutes. If left on it seems to drift ever so slowly down. It always hits 2% on cal around a similar time and if left slowly reduces until you have to adjust.
There accurate within + or -. 25% apparently so id be keen to see how far off it is.
Mick
If you have a good local friendly garage they might stick your car on their machine for a bit of beer money if they aren’t busy, works for me sometimes or I wait till MOT time and get the bit of paper with the reading.
