Page 1 of 2
MOT failure due to excessive play in MacPherson mount. New mounts fitted but still play! Help!
Posted: Thu May 23, 2019 12:32 pm
by mjmaster10
Hi guys
My Mk2 scirocco failed its MOT due to excess play in one of the MacPherson strut mounts at the front. I have had them both changed, and whilst there is no vertical play, the garage have told me that there is still sideways play. The parts were new, and identical to the original parts, including the spacer.
I should clarify that the movement is when the mount is not under the car's weight. This may be entirely normal.
Can anyone help with telling me whether this is normal, or if not what the solution might be, as the garage have now drawn a blank.
Mark
Re: MOT failure due to excessive play in MacPherson mount. New mounts fitted but still play! Help!
Posted: Thu May 23, 2019 12:34 pm
by GTXTRA
Trusted garage?
Second opinion at more of a specialist?
Posted: Thu May 23, 2019 12:52 pm
by mjmaster10
Posted: Thu May 23, 2019 5:10 pm
by chopperoli
Shorten the spacer slightly
Posted: Thu May 23, 2019 5:13 pm
by chopperoli
Also check the washer is present on the rod, just under the spring cap (I don't mean the one under the main nut although you need that one too)
Posted: Thu May 23, 2019 5:55 pm
by mjmaster10
chopperoli wrote: Thu May 23, 2019 5:10 pm
Shorten by filing it down slightly?
Posted: Thu May 23, 2019 6:56 pm
Yes I always get problems fitting new spacers sleeves, I now just use the old one. They are meant to be crushed slightly when doing up the nut but I've never managed to squash one yet.
I do what is suggested and file down the metal sleeve so it's only just proud and pack the thing with grease so stop the knocking, sometimes there's a little resistance when turning the top mount by hand but when on the car it's fine.
You will need the spring compresses again
Is there the washer underneath your nut, it's hard to see in the video?
Posted: Thu May 23, 2019 10:49 pm
by mjmaster10
mark1gls wrote: Thu May 23, 2019 6:56 pm
Many thanks for the advice. The car is still at the garage - I am told that the washer was there below the nut as per the diagram in Bentley
Posted: Fri May 24, 2019 4:31 pm
by chopperoli
Btw if you take too much off you will damage the bearing
Posted: Fri May 24, 2019 5:57 pm
by james butler
might sound daft but what if you put a fibre washer beteen the top washer and crush tube?
the fibre will crush easier and take up the play
Posted: Tue May 28, 2019 4:17 pm
by mjmaster10
So it looks as if there was nothing wrong with the strutt mounts... the new ones have exactly the same play as the old ones, which when the weight is on the car completely disappears.
I would not recommend an MOT from Halfords!
Thanks for all the help.
Posted: Wed May 29, 2019 7:41 am
by essextom
i think if you had mentioned it was a halfords mot station we could have pinpointed the issue very quickly!
Posted: Thu May 30, 2019 9:20 pm
by mjmaster10
essextom wrote: Wed May 29, 2019 7:41 am
I know..... £500 later......
Posted: Fri May 31, 2019 7:14 am
by essextom
£500!
Posted: Fri May 31, 2019 9:51 am
by chopperoli
Err what? Because they forced you to change parts that weren't faulty? I'd be following that up mate...
