Reverse light switch
Posted: Thu Apr 11, 2019 11:45 am
by Lukeh17
Hi,
Just a quick query. I've replaced the bulbs and fuse and the reverse lights still don't come on.
In this link, am I right in thinking that the switch is number 34? I have a 1.6 GT
https://volkswagen.7zap.com/en/rdw/scir ... 301-83000/
Secondly, I take it this will still fit a scirocco even though it isn't listed?
https://www.ebay.co.uk/itm/VW-GOLF-MK1- ... SwnDpaFTjw
Re: Reverse light switch
Posted: Thu Apr 11, 2019 12:44 pm
by PeteGLi
It will fit, but just check that your wiring terminals will fit. Some cars have a molded plug, which require a different switch.
Posted: Thu Apr 11, 2019 1:53 pm
by Lukeh17
Thanks, I'll have to go out and check it.
Posted: Thu Apr 11, 2019 6:07 pm
If you have the 2 wire/pin type you can check to see if the switch is at fault by unplugging the 2 wires, switch the ignition on and touch the 2 wires together, if the reversing lights come on then switch is at fault, if no lights it’s a wiring problem.
Posted: Fri Apr 12, 2019 9:56 am
by Lukeh17
mark1gls wrote: Thu Apr 11, 2019 6:07 pm
Cheers for that Mark. I'm doing the service tomorrow so, I'll check that out and see what happens and depending on the result, will do it at a later date.
Posted: Fri Apr 12, 2019 9:09 pm
Reserving lights now come into an MOT test so you will need to fix it before it's due...
Posted: Sat Apr 13, 2019 3:10 pm
by GT_II
Reversing lights are not tested on cars registered before September 2009, but I guess could well attract an advisory.
Posted: Mon Apr 15, 2019 9:31 am
by Lukeh17
GT_II wrote: Sat Apr 13, 2019 3:10 pm
Useful to know - thanks
Posted: Mon Apr 15, 2019 9:48 am
by unknownmale
If you have a multimeter, put it in continuity mode (Measure ohms resistance) and touch the two pins, there should be no continuity, then put it in reverse, there should be close to no resistance. Worth testing it before replacing!
Posted: Sat May 11, 2019 11:39 pm
by james butler
switches on these are common for getting gear oil in them.
i bought 5 of them in the last euro car parts sale. i have one spare one left and the current one is playing up.
i put a relay in the circuit to reduce the power through the switch and that prolonged the life of the switches.
but theyre not good.
Posted: Wed May 15, 2019 11:19 am
by Lukeh17
That makes sense as where they are positioned. I've just bought one from B&B parts on eBay. Hopefully it'll do the job!
Posted: Sun May 10, 2020 1:34 am
by matisph08
rachat de crédit surendettement, switch the ignition on and touch the 2 wires together, if the reversing lights come on then switch is at fault, if no lights it’s a wiring problem.
And there is therefore no risk of ruining a few relays in passing.
