Hello ever body the springs on sally are to low and need changing as she is now sitting between 35 - 25 mm low we would like to get a set 40 mm . Here the ones I would like you thought's on list ====
[1] Eibach .
[2] H & R .
Thanks very much indeed for the help peoples .
Which Lowering Springs To Buy .
- unknownmale
Re: Which Lowering Springs To Buy .
I would say this depends on the shocks you're using.
For example if you had Koni str shocks I would use H&R springs, bilstein b4s I would run Eibach springs.
I had the Eibach springs on koni shocks before and the front was bouncy and would unsettle, H&R springs on Koni were fine. I've had Eibach springs on Bilstein B4s, this was fine, not tried H&R on Bilsteins though.
Well I brought the suspension set three years ago this year coming up some time it is from Germany cost £159.95 all in with p & p . From ebay I have had abother look for the set on ebay there are no sets on there anymore . Some one here did have a second set on here for sale back last year .unknownmale wrote: ↑Sun Feb 24, 2019 9:12 am I would say this depends on the shocks you're using.
