It took 2 days as i think this car has NEVER seen grease so every pinch bolts etc was corroded in place and took hours of heat and force. The ball joint pinch bolts stuck in place even with the nuts off and some serious hammering
But i got the car all finished off a few hours ago before the snow landed so all is well on that front.
However the front end is now clearly sitting above the rear.
Does it look standard? or has bilstein demonstrated exceptional stupidity once again and sent me a standard height spring pair (the gts etc are 20mm lowered from factory) . They were very vague about it when i raised the issue before i got them.... Or was the car already lowered additionally and ive just put it back to standard?
I have attached a picture so look forward to your responses :) I really wish this had not happened as it means one way or another more work is needed :(
Mick
