Mk1 Bumper Clip/Guide
theboysmiffy
Post by theboysmiffy »
Does anyone know how to remove the plastic guides that locate the sides of the rear bumper? I can see the nuts on the inside of the front wings so the front is not a problem but I can’t work out where they are located on the inside of the rear panel. I want to unbolt them rather than just hacking them off!! Cheers
Blueshark
Re: Mk1 Bumper Clip/Guide
Post by Blueshark »
theboysmiffy
Thanks for the pic. It is part 20,21 and 22 in the lower drawing, the problem is I don’t know how to access the nuts that hold the guide onto the rear quarter panel.
Blueshark
Post by Blueshark »
I do not know either.
Have you taken out the side panels in the trunk ?
Joost
I know on my mk1 I had to go in via the boot and remove the side cards to get access, if you put your hand down there you should feel the big plastic nut which hold the clip on.
theboysmiffy
Thanks both of you, I will have an explore this evening.
theboysmiffy
Found them, located behind the carpet and card in the boot. Thanks again.
