<t>Hi, Just thought I'd share a few Pictures of my Project.<br/>
<br/>
Bought the car 2 1/2 years ago after having a 1984 Mars red GTi (B555VAG) around 30 years ago<br/>
<br/>
Did most of the welding repairs etc. around 18 months ago but got bored. I've now restarted & it's coming together nicely.<br/>
<br/>
Swapped the rear axle out for a powder coated replacement, new stub axles, hubs, calipers & disc brakes. Complete new suspension, wishbones bushes etc. Bilstein Shocks all round. New steering rack. Gear linkages replaced/rebushed. Replacement servo & master cylinder, Wilwood Bias valves to rear circuit. Calibra calipers to front. Just repainted insides of front wings ready to refit. Engines just had rebore, new pistons, rings, shells & big ends. Cylinder head skimmed new valve guides, oil seals & new hydraulic tappets. will rebuild next week with new oil pump, water pump cambelt & tensioner. Weber carb going for refurb.<br/>
<br/>
Hopefull ready for complete repaint after Christmas & ready for road in Spring!</t>
1990 GTII Rebuild
Re: 1990 GTII Rebuild
Few More Pictures
Some serious work there, whilst the engine is out strenghen the bulk head where the clutch cable comes through as it splits there. There is a mk1 repair plate you can get on ebay but needs trimming or there os the south african clutch cable conversion
