down grading mfa to normal
Posted: Fri May 11, 2018 7:16 pm
by james butler
can you fit normal stalks to an originally mfa car?
i dont want MFA in crusty but it had it origenally had it.
Re: down grading mfa to normal
Posted: Fri May 11, 2018 8:44 pm
by Blueshark
Shure you can, if you are not able to operate it will not work.
Joost
Posted: Fri May 11, 2018 10:42 pm
by moser
Mfa on the stalk is completely independent and has its own plug. As Joost said if that plug is not connected then all that happens is the button doesn’t work
Posted: Sat May 12, 2018 3:03 am
by james butler
great stuff
cheers
Posted: Mon May 14, 2018 9:25 am
As long as the sensors are still in place, outside temperature and oil temperature are still useful to have even if the MPG and miles etc don't work?
Posted: Mon May 14, 2018 11:18 pm
by james butler
true but I'm anxious enough person as it is without another gauge telling me the engines about to explode
i wanted to use the MFA on the green car eventually so will need to swap stuff about.
crusty has the ABF so unless i wire it in correctly the MFA probably won't work anyway so rather not have it in there.
