under bonnet insulation
Posted: Mon Apr 23, 2018 2:43 pm
by C 20 CCO
I had to use the vacuum cleaner to remove the original insulation.... Yes it was so far gone the vacuum cleaner made short work of removal. :-o
I've read through previous posts on how to refit and with what material to use; and went for the hardura black pieces from newton commercial classic car interiors.
I managed to take off half the old adhesive off but gave up. To try and soften the adhesive I tried petrol, diesel but plumped for white spirit. I found using a toothbrush and a rigid plastic scraper the easiest way to go, but even so it was a long slow process. The new panels are in place so lets see how long they last and cope with the heat from the engine.
I posted some pictures below, well pleased with the result, challenging to do the long pieces but all gone to plan.
Re: under bonnet insulation
Posted: Mon Apr 23, 2018 2:45 pm
That looks better, you should also stop getting old bits of foam dropping on your engine each time you shut the bonnet! :-D
