Magic Smoke from the Headlights Switch!
Posted: Sat Aug 15, 2009 9:05 am
Hi everbody,
small problem with my 'rocco ('88 1.6GT).... but first some background.
My car's speedo has always been out - 10mph all the way up. So I took the instrument cluster out to recalibrate it. I moved the needle (goodness knows why it was out in the first place) and replaced the panel. All guages work? Good.
About 4 months ago I replaced the indicators.
Now I don't do much night driving at all, but for the first time in ages it was getting darker last night as I was driving so I put the lights on - not full beam, but on. Being a Scirocco, of course, I don't know whether the lights were actually on.
It was around this point I felt like the car was down on power, maybe it was my imagination but it just felt sluggish. Don't know if it sounded off because I had The Rolling Stones on too loud to hear.
Bit further down the road and I notice pretty wisps of smoke coming from the headlight switch on the dash! "Eek!" thinks I, and immediately pulls over and switches everything off. Smoke stops. Check under bonnet - all fine. Luckily it's still not dark, just heading towards dusk, and I'm only 5m away from my destination... so I continue and get there no problem.
Now a little more investigation this morning....
* Lights on but not on full beam (middle position on switch) - nothing. No lights. Dashboard lights light up (not very bright, but it's daylight now).
* Flash lights - lights come on. Dashboard indicator for full beam doesn't light up.
* Full beam - Lights go on full. No dash indicator.
* Dipped lights - Lights dip. Still no dash indicator.
That's where I am now. I've removed the instrument panel as the speedo still is a little fast, and it looks like the little bulb for full beam has gone. Also the clock is being eaten up by blackness (typical old LCD disease).
Does anyone have any suggestions? Can the instrument panel have caused the smoke from the headlights switch? Could I have knackered something up that'd cause that? Why don't the lights work except on full beam now, and did I just imagine the loss of power, or is it shorting?
I would very much appreciate any help you can all give. Can you still get new instrument panels that'd fit? Maybe that'd solve the problem? Or is it just a coincidence and it's actually the headlights switch that's causing the problem, and all that's wrong with the panel is a blown bulb on the headlights light?
Edit: Is eBay lot #220466167417 the right part?
Thanks for any advice!
