Page 1 of 2
mk2 vr6 turbo 4motion build
Posted: Sat Dec 30, 2017 1:51 am
by chris_mellor
hi all,
i'm currently building a 24v vr6 turbo 4 motion ,if someone can point me in the right direction on where to upload pictures i've got plenty to add ;) the current aim for the car is around 750-800 whp :) so far the car has been stripped to the bare shell and put onto a rotisserie, the rear floor has been removed and the necessary strengthening is nearly complete.
Re: mk2 vr6 turbo 4motion build
Posted: Sat Dec 30, 2017 10:59 am
by mr.brown
You can upload pics direct to this thread by clicking on "Full Editor & Preview" at the bottom of the Quick Reply text box below and then the Attachments tab below it. There is a maximum size, however.
My personal preference at the moment is IMGUR, which is free and has no restrictions (currently) on links to photos stored there.
It's fairly easy to open an account and start uploading. It also has a mobile app so you can upload direct from your phone.
Once you've uploaded your pictures, each one has a drop down menu with "Get share links" on it. All you need to do then is Copy the "BBC Code(forums)" link and paste it into your thread here.
Posted: Fri Jan 05, 2018 1:40 am
by chris_mellor
Posted: Fri Jan 05, 2018 1:45 am
by chris_mellor
Posted: Fri Jan 05, 2018 1:50 am
by chris_mellor
Posted: Fri Jan 05, 2018 6:15 am
by BlackGTX
Excellent build, good to see Some one tackle a prop tunel with sucsess
Look forwad to seeing this come together
Posted: Fri Jan 05, 2018 1:26 pm
by scrappy1382
now this looks like a very interesting build i shall be watching/ reading . looking forward to seeing the end result. i know you are very early into the build, but have you thought about just making it rear wheel drive ?
Posted: Fri Jan 05, 2018 2:19 pm
by chris_mellor
to be honest its never really crossed my mind to be rwd , would be very intresting though ,by using the haldex diff i will be able to switch from awd to fwd but with the power output i have in mind i fear that two wheel drive may just do a heap of spinning
Posted: Fri Jan 05, 2018 6:06 pm
Wow this is what you call a project, hats off to you for carrying out such a built.
This is 1 to watch.
Posted: Fri Jan 05, 2018 8:27 pm
by james butler
this will be an interesting build!
the scirocco is quite a floppy car, with that much power going through it are you going to put a roll cage/ space frame into the car to tighten the body up?
Posted: Sat Jan 06, 2018 1:28 am
by chris_mellor
yeah the car will be having a full roll cage and more gussets/strengthening in any place of weakness or where the car is already lacking strength , the car seems a lot firmer in the rear already due to the cross bars that the subframe mounts up to .
Posted: Sat Jan 06, 2018 1:51 am
by chris_mellor
Posted: Sat Jan 06, 2018 5:03 am
by james butler
that makes sense, looks great so far
keep the piccys coming
have you seen this guy?
http://www.stanceworks.com/forums/showt ... rabbit-GTI
he did very similar to you and the mk1 he used will have lots of similar obstacles as the rocco as its similar/same floor pan
Posted: Sat Jan 06, 2018 10:54 am
by chris_mellor
yes mate ive read the whole build thread on vw vortex a while back it was one hell of a read and there was a LOT of fabrication that went into that car , sadly it is now sitting next to eurowise with a cover on it , the car got 90% finished and then the owner moved house etc and sadly the car has been forgotten about a bit
Posted: Sat Jan 06, 2018 6:27 pm
by james butler
ahh no way!
no wonder it went so quiet.
well keep up the good work and look forward to some more piccs
