Overheated... I think...
Posted: Fri Aug 14, 2009 6:25 pm
Hi guys, I need a little help if you would be so kind.
I was driving home from work today, stop start traffic. There was gradually a load of steam from under the bonnet. The fan had been kicking in fine all day, although with the traffic I couldn't hear it (might test and change the fuse). There was no warning light on inside the car and to be honest the temp seemed OK on the dial. Home now, after turning the engine on and off all the way (which is a sod with an immoboliser!!) I have had a look under the bonnet and cant see any hoses or leads that are untoward but there does seem to be liquid dripping from the air box/carb down onto the engine. Cant see if its fuel or something else. There was a healthy supply of fuel and it was retracting back to the tank when I turned the engine off.
I know its a long shot, but any help would be greatly appreciated. Thanks in advance.
Andy
Andy
