Judder/stutter on more than half throttle
Posted: Fri May 26, 2017 8:58 am
Hello all,
Another thing to try and sort
When I'm in low revs, sub 3k, and I press the throttle, there's a certain point where the car seems to judder/stutter. Then when I ease off the throttle, there's a point where it seems to pick up again.
The clutch is slipping but this seems like a different issue as it seems to be when I go past a certain point with the throttle. I've changed the plugs and coil a while back, carb has had a good clean too, haven't checked the timing or anything. Any ideas?
Thanks again, Liam
Thanks again, Liam
