Spark Plug Torque
liam_0404
Spark Plug Torque
Post by liam_0404 »
Hi,
What should I set my Torque wrench to for the spark plugs on a 1.6 Scirocco MK2, can't seem to find any info on it anywhere.
Liam
'88 Scirocco 1.6 8v GT
‘94 Golf 2.8 12v VR6
'02 Grand Cherokee Limited 4.0 I6
'07 Golf GTI 2.0T
steve bain
Re: Spark Plug Torque
Post by steve bain »
I can't remember, but it's in Haynes. I was quite suprised, turned out I had not been doing them up tight enough for years. I swear it was 34nm, but defo check...
My build thread:
viewtopic.php?f=19&t=14083
its usually on the side of the packet of the plug.
im pretty sure 34nm is too much as the bosch plugs typically state 25nm and a 1/4 turn.
duggers
Post by duggers »
It's 20NM
Membership # 432
unknownmale
Post by unknownmale »
I go for snug plus a 1/4 turn to help me sleep at night. I make a click sound with my mouth too.
steve bain
googe says 20nm. ignore what i said
My build thread:
liam_0404
Post by liam_0404 »
Thanks for the info everyone. The plugs themselves said 28Nm, so I went for 24Nm as it was in between!
Cheers, Liam
'07 Golf GTI 2.0T
unknownmale wrote:I go for snug plus a 1/4 turn to help me sleep at night. I make a click sound with my mouth too.
i normally just shout "click"
i do it with wheel nuts too
