head light upgrade loom important info!!
Posted: Mon Mar 20, 2017 3:51 am
most of you have probably fitted the headlight relay upgrade loom to your cars but have you noticed you get dipped beam on both positions of the headlight switch???
so how do you get just your sidelights?
under the slam panel just behind the passenger headlight is a large resister wired into the sidelight wiring that goes to the dipped beam, unplug and remove the resister and hey presto you have sidelights only on the first position of the headlight switch!!!
nice easy fix
nice easy fix
