Lcd clock and heater slider clip
Posted: Sat Dec 17, 2016 9:03 am
by Redline
I need advice. I have purchased a set of mk2 clocks with mpg/oil temp lcd screen. I've started stripping the lcd out.. will it fit my clocks that doesn't have these features...ie have I wasted my money. Also the slider heater clip that retains the knobs.... where can I get these.... my car is an 86 GTS. I appreciate your help. Thanks
Re: Lcd clock and heater slider clip
Posted: Sat Dec 17, 2016 12:01 pm
by unknownmale
I think the LCD unit is the same regardless of the MFA computer. I did a little how to on replacing them here -
viewtopic.php?f=11&t=17624
Posted: Sat Dec 17, 2016 1:18 pm
by Redline
The lcd looks different to what your pics show.
Posted: Sat Dec 17, 2016 6:09 pm
by bengould
It is different. I had my clocks stripped bare and swapped the LCD from a set of MFA clocks in. It didn't work.
You can however swap the entire center and rev counter section from the MFA clocks into yours and just the time will show on the display.
Ben.
Posted: Sat Dec 17, 2016 10:54 pm
by james butler
as ben says the LCD clocks aren't interchangeable between different clock types.
Posted: Sun Dec 18, 2016 1:49 pm
by Redline
Thanks guys.
