Battery Terminal Clamp - Unidentified Connector
Posted: Sat Oct 22, 2016 11:14 pm
I've noticed that the negative battery terminal clamp on my Mk2 has a spade-type male terminal as part of it, but there isn't any wire in the vicinity to connect to it. The only wires are the braided copper battery wire and two thinner wires with light brown insulation that are held to the terminal clamp via a loop connection that the tightening bolt passes through.
This is bugging me, as I've only just noticed it and it doesn't look right. The positive terminal also has the same spade connector, but there is a red wire connected to this (presumably for my alarm).
Does anyone else have this spade connection on the negative battery clamp?
