Headlamp Adjusters
Posted: Wed Sep 21, 2016 8:31 am
by Mark H
Got a couple of Headlamp Adjusters that are either damaged or broken on the Rocco, is their any way of either fitting new adjusters individually without fully stripping down the complete headlamp unit or leaving the existing back plate plastic in place and just removing/replacing the adjusting screw?
Mark
Re: Headlamp Adjusters
Posted: Wed Sep 21, 2016 9:50 pm
by GTXTRA
Hi Mark, depending on which bit is broken - I usually find it's the small round fastener that clips into place on 'front' end of the metal rods - I have been able to replace just the broken bit on an adjuster.
If you can get some pliers onto the rear element and twist they will pop out - if you have a few of the small white fasteners you will be able to fix most adjuster issues.
Hope that helps?
Posted: Wed Sep 21, 2016 11:00 pm
by Mark H
Cheers Sean, parts on the way from Joost..
Posted: Sat Sep 24, 2016 7:50 pm
by james butler
dont the e30 bmw clips fit too? seem to remember someone using them on here?
http://www.ebay.co.uk/itm/HEADLAMP-HEAD ... Sw9eVXXSiR
They were the same part at GSF for a while, and what I used to fix the lights on a GTII, so I'd say yes.
Posted: Sun Sep 25, 2016 9:41 pm
by Mark H
Cheers James, all bits came on Friday from Joost. What I really need is a couple of the black plastic inserts the frames screw into to locate ?
Posted: Sun Sep 25, 2016 10:52 pm
by james butler
are these the ones that go into the slam panel on the car? i will have a look as i might have some floating about.
failing that they should be quite a common fitting on other cars so you might be able to upcycle something from a scrap yard
Posted: Mon Sep 26, 2016 8:37 am
by Mark H
Yes these are the ones in the slam panel..
