1.8t conversion fuel pump/ swirl pot
essextom
Post by essextom »
After some advice from previous 20v converters. My car was originally carb so no fuel pump, I've got a Bosch inline pump which I can fit straight after the tank which will work, but I have also got a 1lt fuel swirl pot, so I could use a lift pump to the swirl pot and then inline pump to engine, fuel return to swirl pot and then swirl overflow back to main fuel tank. My question is- has anyone gone either route and had any problems and also what lift pump have people used? Or should I just inline pump straight from tank to engine?
Re: 1.8t conversion fuel pump/ swirl pot
Post by mr.brown »
What year is your mk2?
Post-84 with 55 litre tank use the standard mk2 Scirocco/mk1 Golf cabriolet lift pump.
Pre-84 with 40 litre tank use just the inline pump.
essextom
Post by essextom »
Mines an 88, I'll just use the inline and see how I get on
bengould
Post by bengould »
Use the lift pump from an injection car to feed your swirl pot and feed your main pump from that. It will give the main pump a bit less work to do and will eliminate fuel starvation on bends/steep hills. I ran with just a lift pump and main pump for a while but had to put a swirl pot in due to this.
Ben.
essextom
Post by essextom »
I'll swirl pot it just to be on safe side, I've got one sitting about.
daft question but would it be better just to have a tank with the out let at the bottom of the fuel tank?
essextom
Post by essextom »
Yeah my outlet is at the bottom of the tank I think, but when you hoon it round a corner all the fuel could spill to other side of tank and I'd have fuel starvation
Post by mr.brown »
Carb tank has no "outlet" as such - it's just pipes going in via the sender unit - the same place as the lift pump would go.
essextom
Post by essextom »
So would a lift pump/ sender unit from an inj car fit straight in?
Post by mr.brown »
Yes. But don't forget you'll need to wire it in. In theory - as the injected and carb cars have the same fuse box - if you were to get hold of the rear loom from an injected car it would plug straight in as would the fuel pump relay. In theory.....
essextom
Post by essextom »
Yeah I was thinking that. If not a fuel pump loom is pretty easy to knock up.
Post by mr.brown »
Pump in question - to be found on mk2 Scirocco / mk1 Golf Cabriolet injection from mid-84 onwards and also mk3 Polo 1991-93 ish. As you can see, the top flange is identical to carb cars.
The one in the picture above is from a Polo as Mk2 Scirocco and Mk1 Golf cabriolet have the electrical connection on a different angle, Polo pump straight up and Scirocco/Golf on a 90 degree angle.
My Mk1 Golf Cabriolet lift pump.
3 electrical connections.
connorj19
Post by connorj19 »
I'm doing the same conversion, bought the lift pump from Ben on here which is going to feed this, it's a swirl pot & main pump in one... anybody tried this method or just me? It's going into the boot floor as my brakes are too big for a space saver anyways Image
Image if anybody is handy you could probably replicate somthing similar
that looks like a good idea conner.
webcon sell them cheaper though as i think thats where demon tweaks get them from
http://www.webcon.co.uk/shopdisplayprod ... I+Pressure
its worth talking to ant who modded the tank to take the standard pump and swirl pot from audi a3 tank as its designed for this engine.
viewtopic.php?f=19&t=19427&start=45
scroll down towards the bottom and you will see.
theres a guy who runs a place called readyrads in Birmingham who cuts tanks up for rust treatment who should have no problem doing the fabrication work for you to fit the original pump.
just another avenue you could look at.
if you give shane crosby a shout aka scrappy1382 he now owns the car so might be able to get some more pictures of it and some dimensions.
