Retro fitting air conditioning to a 1986 GTX Scirocco
Posted: Tue May 10, 2016 1:41 pm
by mjmaster10
Hi Guys
Do anyone know whether this is possible, and what the cost might be? Is it feasible?
Mark
Re: Retro fitting air conditioning to a 1986 GTX Scirocco
Posted: Tue May 10, 2016 2:27 pm
I think GTXTRA had air con in his Scirocco which he removed?
To find an original set up is going to be tricky as not many UK cars was fitted with it, you would need to search the USA or possibly Germany?
Posted: Tue May 10, 2016 8:14 pm
by sabre0699
Did the South African Citi Golfs not have it as standard as well
Posted: Wed May 11, 2016 7:40 am
by Mr Funk
Yeah, Sean had it.
Hated it, got it taken out.
Posted: Wed May 11, 2016 7:24 pm
by bengould
Have a look at https://www.youtube.com/channel/UCtgQLr ... sZzYrJE_DQ
The guy is a bit boring but building an impressive spec Mk1 with an electric A/C system.
Not sure which videos it is in but his titles give a pretty good indication as to what is going on. There's a few that cover the A/C system.
Ben.
Posted: Wed May 11, 2016 8:48 pm
by unknownmale
I've watched all of Dereks videos...Very impressive. But he's using an electric AC pump, not belt driven, and they don't really put out enough energy to be worth it in my opinion...Plus it's controlled by his ECU.
Fairly sure most of the US and German 16v had air con, if you search for a breaking car in germany or in craigslist in the US you could grab the parts.
There is a 1.6 engine for sale on CL at the moment in CA with all the AC bits on, Probably wouldn't include a condenser though or the interior controls/ wiring. But fairly simple to set up if you have the pump, bracket, lines etc.
Posted: Wed May 11, 2016 11:52 pm
by james butler
cannibalise a system off a mk3 golf then mod the scirocco to suit.
most of the gubbins should bolt up to the existing block
Posted: Mon May 16, 2016 3:54 pm
by mjmaster10
Thanks very much guys
Posted: Mon May 16, 2016 8:25 pm
by jakeb
Ripped the aircon off my mk2 and held onto all the bits. Broke most of the pipe work but sure new bits could be made up using what remains as a guide. May be better off using mk3 bits as suggested above but it's all taking up space in the dads shed so welcome to it if you want it.
