Another gauge question
Posted: Wed Apr 27, 2016 9:13 pm
I've had a look but can't find the answer to my question, sorry if it's been posted before.
1.8 DX scala, late model, looking to fit gauges I nabbed from an '84 audi years back. So basically i have the audi specific oil temp sender, which I will add via a tee to the existing MFA temp sender, fine, but I also have the filter housing (rather than head) based oil switch / pressure twin pole sensor for the 5 bar gauge and 1.8 bar pressure built in alarm. Thing is the dual sensor won't fit in the same place as the existing switch at the back of the filter housing as it's fouled by the allen bolt head being much fatter.
Can I swap the temperature sensor and pressure switch locations, i.e. can I run the temp sensor at the back and the dual pole sensor switch/pressure gauge at the front? I believe they are both 10mm/1mm pitch thread but am not sure of the internals of the filter housing whether it will give me issues with pressure and/or temperature detection after swapping.
Andy.
Andy.
