Fuel pipe clips
GTXGTXGTX
Fuel pipe clips
Post by GTXGTXGTX »
After removing lift pump recently I want go replace the original correct fuel pipe clips. Does anyone know what they are called or where I can get them and the correct pliers to fit them? Thanks
Re: Fuel pipe clips
So you're after the annoying spring loaded ones? They're on evilbay. Search for 251162915816 loads of people selling them, check the size of your pipe before ordering.
To fit them, use any pliers you have to squeeze the lugs together and expand the ring. Slide it over the pipe. Push fit the pipe onto the required spigot, then open up the clip again as before and slide it up to the end of the pipe.
I have a huge selection of special pipe clip tools, but it doesn't make it any easier than just using pliers or pipe grips
Re: Fuel pipe clips
Nate wrote: I have a huge selection of special pipe clip tools, but it doesn't make it any easier than just using pliers or pipe grips
or use fuel pipe clips
https://www.google.co.uk/search?q=fuel+ ... AhX4tGM%3A
Re: Fuel pipe clips
Bog standard fuel hose clips will work, don't use normal jubilee clips as they can just squash just one part of the hose and can leak.
Any motor factors will sell them.
Look like this.
http://www.ebay.co.uk/itm/MINI-FUEL-LIN ... IwY3H_6_FQ
Re: Fuel pipe clips
mark1gls wrote:Bog standard fuel hose clips will work, don't use normal jubilee clips as they can just squash just one part of the hose and can leak.
Look like this.
yep there the ones,
i use them all the time especially as they are reusable
