Rejetting?
barefoot
Rejetting?
Post by barefoot »
It has come to my attention that I'm running the wrong carb. It's the replacement Weber, but it's apparently jetted for an 1.8 and I'm running it on my 1.6.
Is it possible to rejet & if so, what size do I need & where do I get them from?
Thanks in anticipation.
unknownmale
Re: Rejetting?
Post by unknownmale »
primary secondary
main jet 120 125
air corrector 155 155
emulision tube f-30 f-25
idle jet 50 50
pump jet 45
Re: Rejetting?
Helpful place with should be able to advise you on which bits you need. I had trouble finding info/bits for my DMTR carb fitted to my Mk1
http://www.fastroadcars.co.uk/shop/index.php
bengould
Re: Rejetting?
Post by bengould »
http://www.webcon.co.uk
The guys that run the place know all there is to know about Weber carbs.
Ben
barefoot
Re: Rejetting?
Post by barefoot »
Thanks everyone, that's great.
