My stupidity has shone through as I took out the old light switch lightbulb and left the connectors dangling, they must have touched while driving, causing a short circuit. Ideally, fuse 14 (20A) would have blown but no, it melted for some reason without breaking circuit. Resulted in some smoke from melted wires. It also seemed to have broken the heater blower motor. I've replaced motor so blower is working again. The simplified circuit I've traced out looks like this, with the red denoting the melted wires.
1. Is this light bulb indeed meant to be part of the circuit of fuse 14 (20A) which powers the heater blower motor?
2. The fuses were cheap eBay ones - is it common to have bad/faulty fuses where the plastic melts? Or is it more likely that fuse contacts were dirty so wasn't conducting well?
3. To replace the wire which has melted, is is sufficient to get any > 0.1A rated wire since the bulb is 1.2W / 12V?
4. The melted brown wire out of the lightbulb goes into a bundle of 4 brown wires where the cores are united together over about 1cm, covered in tape then split back into 4 wires. Why would a previous owner have done this?
Here's the heater blower motor switch. 3 wires on right are to motor's resistor pack, red/black wire is from fusebox and meted yellow/black wire to light switch lightbulb.
