VR6 misfiring problem - all cylinders firing, but down on power
Posted: Sun Oct 18, 2015 4:36 pm
Hi chaps, i know this isn't the Raddo forum (have asked over there as well), but I'm sure some of my fellow Corrado-ers might be able to help me.
My VR6 has started running badly as of yesterday:
Another issue that I've noticed in recent times is oil smoke from the exhaust, suggesting valve stem seals are going. Is it likely that some of the spark plugs are getting oily and this is what's causing the issue?
To further complicate things, since this problem reared its head yesterday the oil burning seems to have stopped!
Only other thought is the coil pack - hopefully not though.
I know I could just go and check the spark plugs but haven't got much of an opportunity to work on the car, and it needs serviced anyway.
cheers
- Down on power
- slightly lumpy idle, like you can feel the car sort of jump slightly every couple of seconds.
- lumpy sound and ragged response when throttle floored, not smooth
cheers
