grit blaster
grit blaster
ive been looking at grit blasters but not sure which one to go for.
usually the things i need blasting are quite small so some thing like a small cabinet would be great.
but then there are times that being able to blast large objects or areas like chassis parts and what not would be easier than grinding or sanding, so a pressurised blaster that you can use outdoors seems a better idea. but then if ive got some thing that big i might as well take it to a shot blasters and pay them to do it and save the mess.
heres the two im looking at.
https://www.machinemart.co.uk/shop/prod ... st-cabinet
and
https://www.machinemart.co.uk/shop/prod ... andblaster
Re: grit blaster
Which one would you guys choose if you had the choice?
unknownmale
Re: grit blaster
Post by unknownmale »
Think the CPSB100 is your best bet, much more versatile. You can always make a small cabinet to contain the mess for smaller bits. One of those cheapo metal garden tool sheds or something.
Re: grit blaster
Post by mr.brown »
Do you have a compressor already? If not, add £200 to your budget if buying the first one.
Re: grit blaster
unknownmale wrote:Think the CPSB100 is your best bet, much more versatile. You can always make a small cabinet to contain the mess for smaller bits. One of those cheapo metal garden tool sheds or something.
cheers, thats what i was thinking as sods law if i get a cabinet type blaster i will inevitably want to do something that wont fit inside it.
mr.brown wrote:Do you have a compressor already? If not, add £200 to your budget if buying the first one.
cheers for the heads up mr brown, i do have a compressor hopefully it will be up to the job.
i have this one at the moment and it seems to run most things.
https://www.machinemart.co.uk/shop/prod ... air-compre
dozzum
Re: grit blaster
Post by dozzum »
You can get those pressurised blasters on ebay for half the price.
Re: grit blaster
dozzum wrote:You can get those pressurised blasters on ebay for half the price.
ahhh dozzum dont tell me that now ive allready bought one! :dash:
never mind, thanks for the heads up though. :hi:
