Morello Magneti Rad Fan Help
Roccogtx332
Post by Roccogtx332 »
Ok guys, one to get your teeth into. Looks like VW fitted the rarest radiator fan in the world to my rococo. It's a 6 bladed black Mirelli Magneti 2 pin plug fan. Now you can get 6 blade 3 pin fans and 4 blade 2 pin (but the plug is the wrong size- too big) for this 1986 GTX. Anyone come across this before? Otherwise a trip to VW maybe on the cards :(
Rocco '86 GTX all original driving project
essextom
Re: Morello Magneti Rad Fan Help
Post by essextom »
I've got a spare rad fan at home, if you message me fri so I don't forget I'll see what I have.
change the plug?
essextom
Post by essextom »
Checked out my spare fan Nd it's some aftermarket bodge thing
i would go down the scrap yard and take a complete fan with loom from a golf or something as most of the actual fan parts are interchangeable.
its only the cowling thats unique to the car, all you have to do is cut your old plug off and fit the new one.
Blueshark
Post by Blueshark »
Should it not be "magneti marelli" ?
Joost
MattRocco
Post by MattRocco »
I have my one I took off my 87 gtx this weekend, looks like what your describing? I can't post though so would need collecting but you'll probably end up being to far away
