Page 1 of 2
Dipstick Guide
Posted: Sat Aug 29, 2015 5:44 pm
by Lukeh17
The plastic snapped halfway up today so need to order a new one. Do they slide off or not? How do you replace them? Thanks
Re: Dipstick Guide
Posted: Sat Aug 29, 2015 6:02 pm
by james butler
plastic bit at the top pulls off then slide new one back on till it clicks into place.
Re: Dipstick Guide
Posted: Sat Aug 29, 2015 6:23 pm
by Lukeh17
sweet cheers buddy
Re: Dipstick Guide
Posted: Sat Aug 29, 2015 8:40 pm
by PeteGLi
Warm up the plastic with a hairdryer before you push the new one on - or it will just snap on you.
Re: Dipstick Guide
Posted: Sat Aug 29, 2015 8:55 pm
Mine broke into bits when I removed the old one so be careful not to drop to much down the hole.
Re: Dipstick Guide
Posted: Sat Aug 29, 2015 11:22 pm
by marcus
Ooh err missus!
Re: Dipstick Guide
Posted: Sun Aug 30, 2015 3:34 pm
by Lukeh17
haha Thanks for the tips guys
Re: Dipstick Guide
Posted: Sun Jan 10, 2016 2:11 pm
by Lukeh17
So the plastic bit has been on awhile now, but it never seemed to fit properly so when I pull the dipstick out, the whole plastic bit comes off too, this is because part of the old one is stuck down the pipe still, it isn't shattered or anything, it just seems where the rest has come off there is a circular part down there.... any ideas on how to remove this?
Re: Dipstick Guide
Posted: Sun Jan 10, 2016 3:14 pm
by DT1
A metal coat-hanger. Snip a straight bit off and then bend the end over 1 or 2mm to form a small lip. Using 2 at once will probably be best.
Re: Dipstick Guide
Posted: Sun Jan 10, 2016 7:46 pm
by Blueshark
Tak e a thread cutter of good size and turn it in and pull the remaining bit out .
Joost
Re: Dipstick Guide
Posted: Thu Feb 18, 2016 8:01 pm
by Lukeh17
I will try this method, however I am concerned that the plastic is attached to where it's sat in the pipe. Also I am also concerned about dropping it into the sump as this probably wouldn't be a good idea!! Any other suggestions or is the metal coat hanger etc the best method?
Re: Dipstick Guide
Posted: Fri Feb 19, 2016 11:01 am
by james butler
Take the metal pipe off first?
Re: Dipstick Guide
Posted: Mon Feb 22, 2016 3:13 pm
by jpr1977
Put a twisted bit of tissue/kitchen role part way down the dip stick tube/ guide before you start and you can prise the remains of the old guide off with some mole grips then once removed pull out the tissue
Re: Dipstick Guide
Posted: Sat Mar 05, 2016 2:50 pm
by Lukeh17
james butler wrote:Take the metal pipe off first?
How do you remove this?
Re: Dipstick Guide
Posted: Sat Mar 05, 2016 6:05 pm
by james butler
it either screws in or just pulls out.
my mates audi tt one just pulled out but there is a small 10mm bolt holding onto the block on the tt.
im sure i yanked mine out by accident years ago.
the only other way to do it would be to remove the sump then push the broken plastic out through the bottem of the dipstick pipe so you can get all the pieces.
