Hi all
I'm replacing a leaking wheel cylinder on the drum brakes of my 88 GTX
GSF / EPC list 2 types of cylinder, one for cars with a 'brake-power regulator' and one without
Any idea which one i would need?
Marcus
Which wheel cylinder?
- bengould
Re: Which wheel cylinder?
Have a look at your master cylinder.
If you have 2 big cylinders that screw in between it and the copper lines to the rear you have regulators. If not you don't.
Ben.
Ben.
- scirockirb
As above.
If you ring them and give them your registration, they'll make sure you get the correct ones (assuming they're standard).
- bengould
Do NOT do this. LOOK, the reason being, if someone had added the regulators to a car that shouldn't have them and added the cylinders to suit then you get cylinders for a car that shouldn't have them and your brakes don't work.scirockirb wrote:
Also double check the part you get against the one you need, preferably before you leave the shop. The amount of times I have been give a wrong part by suppliers is unbelievable.
Ben.
- scirockirb
- Gilb666
Thanks guys, I'll try and get a look at it tonight.
Expect a picture tomorrow after I realise i don't know what I'm looking at!
Picture of rear brake regulators fitted to my 1988 Mk1 Golf cabriolet, the 2 big things fitted to the bottom of the master cylinder.
