scala 89 1.9i
When i start the car from cold the revs are erratic like it is struggling then it settles, if i rev it when i stop it bottoms out and almost stalls (some times does) This is causing problems changing gear also. Its getting worse and happening more and more not only when cold but rarely stalls when warm but trys sometimes.
Im guessing at ingition system/electrical, but i dont know how to test the seperate bits and what to test as im learning while go.
Ive checked the battery and the charge is good, so what does that leave,
1)Spark plug
2)Spark plug cables (check by looking and make sure not burnt or damaged ?)
3)Dizzy (just check cap for burns and damage ?)
4)ignition coil
5)Module whatsit
6)Timing ?
How can i check this things and what else should i check ?
Need some help with warm up problems
- bluestreak56
Re: Need some help with warm up problems
Seems like the same thing I have and a few others on here too :
http://www.sciroccoregisterforum.co.uk/ ... tors#p4494
Worth reading?
Worth reading?
thanks bud,
might have a look at the WUR as im not getting any backfiring like some of the other.
- b5byt
Mine has just started doing the exact same this morning!
1984 Scirocco Storm Cosmos Blue < Body has really had it, if you need parts off it let me know < Going.
1986 Scirocco Scala (Rocco-Jocco's old one) Having some life put back in to it
2001 Carbon Black E39 M5
2008 Carbon Black E60 M5
I've had a similar problem last few days, but it's been persisting down with rain and I think everything may have got a bit 'damp'.
Try some Dampstart, I know it looks crap when it dries, but it works for me.
Have the same problem with the wife's P*l*.
..also check the wiring to the cold air start valve (assuming it's injection).
Hope this helps
John
Hope this helps
John
