Anyone know what this hose is / does?
Any idea why if i clamp it the revs/idle drops significantly?
The original hose was cracked and damaged, so I replaced it with a new piece of hose (just some bog standard hose i had spare) and it seems to have helped lower the idle slightly but not completely.
It goes into a T-Piece (this is fitted into the rubber boot part on the throttle body), then runs to the back of the cylinder head. The other part of the t-piece goes to the lower connection on the idle valve attached just near the R/H suspension turret
