guys just bought mint set of seats fronts look straight swap
anyone done rear bench? presume some welding etc
corrado rear bench
Re: corrado rear bench
This should give you a good idea of what would be involved mate-
http://www.matey-matey.com/corrado_seat ... sion.shtml
YES read that
rear seat base needs cutting from rocco and then trim bottom corrado rear base
covers to fit, rear backrest needs bolts/studs welding to floor....
looks do able will attempt later.
fronts fit lovely
fronts fit lovely
Corrados fronts wil fit in a mk1 and mk2 but the Scirocco mk2 fronts will not fit the Corrado as they are too wide
making up brackets tommorow to fit rear bench
have an old polo seat foam to cut rather than the scirocco original
rear split seat back is in welded bracket to floor as 1st attempt
need to remake bracket slightly bigger and move seat pins onto brackets.
bit of pita but looks good
