Ignition timing advance
Posted: Thu Mar 05, 2015 12:07 pm
by unknownmale
Is anyone free to take a look at their haynes manual and let me know what the advance is for a 1.8 auto mk2 please?
I've left mine miles away!
Re: Ignition timing advance
Posted: Thu Mar 05, 2015 2:52 pm
Advance it till it pinks under load then retard the timing a little till it stops.
This is the only way I do mine.. :-D
Just make a mark on the dissy shaft near the clamp so if it all goes wrong you can put it back.
Posted: Thu Mar 05, 2015 7:46 pm
by Little_bro
As per Haynes. Ignition timing at idle
Engine type
Jb,fr,eg. 0+-1 with vacuum hose attached
Ew,ex 18+-1 with vacuum hose attached
Ex 6+-1 with vacuum hose detached
Posted: Thu Mar 05, 2015 10:53 pm
by unknownmale
Bloody gun died so I just shifted it about until it sounded right!
Posted: Fri Mar 06, 2015 9:04 pm
Seriously, just keep advancing it little by little until it pinks under heavy load, then back it off a touch to stop it pinking. Will run much nicer than set by the book
Posted: Sat Mar 07, 2015 8:37 pm
by james butler
i gotta ask what is pinking and what does it sound like?
i thought i knew but after chatting with a mate im not so sure now.
Posted: Sat Mar 07, 2015 11:39 pm
Nasty rattly pingy noise, usually when engine is under load. causes are fuel compression igniting before the spark fires, or the spark fires too far before the piston is at the top of its travel, so it is still rising as the fuel burns
Posted: Sun Mar 08, 2015 12:17 am
by DannyH
What he said but for we simple souls that ain't got a clue it sounds like pink pink pink hence the name????
Posted: Sun Mar 08, 2015 2:22 am
by go-for-it1
Put your car into too high a gear for the speed you are doing and then put your foot down, do it going up a hill if you can, if its gonna pink then thats the time it will do it. Its a distinctive tinny rattle in line with the firing sequence, like you've got a marble in one cylinder.
