windscreen washer pump not working but got 12 volts?
Posted: Tue Dec 23, 2014 7:58 pm
hello
after the rebuild i can't get my washer pump to work. after I connected the pump back up i got the jets to spray a couple of times, but since the mot the jets won't spray as the pump won't pump. if I disconnect the wires from the pump and pull the washer jet stalk the wipers do their cycle and there's 12 volts at the connector. so there's voltage at the pump.. but when i connect the wires and pull the stalk the relay doesn't click and the wipers don't do their cycle, the pump won't turn and there's no spraying at the jets.
logically it sounded like a bad pump but i've replaced it with a new one and it does the same.. almost like the connector shorts when plugged into the washer pump? checked fuses and they're all ok.
anyone got any ideas? i'm getting tired of having to pour bottled water onto the windscreen! cheers
