Fuel Lines / Connectors ??
isaidthephil
Post by isaidthephil »
I am wanting to replace all my fuel lines this winter with stainless braided stuff. Can anybody give me some info on this?
What I want to know is;
1. What mm piping should I buy?
2. can people recommend good connectors? I am looking at things like this - http://www.ebay.co.uk/itm/AN-8-AN8-BLAC ... 3f291ae4df but am not sure whether i can use these on my Facet Fuel pump and Filter King fuel reg etc.
Thanks in advance
Little_bro
Re: Fuel Lines / Connectors ??
Post by Little_bro »
I can highly recommend marine grade A2 fuel hose. Have used it quiet a bit on aircool engines with twin carbs and facet pumps Don't know what size for roccos
MRMENDER
Post by MRMENDER »
Fuel hose for Injection engines should be 8MM Internal Diameter, 6MM carb engines.
I am not sure you need braded hose. Ive used unleded fuel hose with a safe working pressure of 10 bar. Working pressure is 8 Bar. I got all my bits from these guys
http://www.advancedfluidsolutions.co.uk/
PeteGLi
Post by PeteGLi »
MRMENDER wrote:Fuel hose for Injection engines should be 8MM Internal Diameter, 6MM carb engines.
Have to remember that place - it is just down the road from me!
isaidthephil
Cheers guys :)
monzajake
Post by monzajake »
Crazy quiff do a kit. Unbolt , bolt in new
Done.
MRMENDER
Post by MRMENDER »
monzajake wrote:Crazy quiff do a kit. Unbolt , bolt in new
Done.
At a price, a ridiculous price!
You should be able to get all the bits to replace all underneath fuel lines for about £50-60 Against £160
isaidthephil
I am running a non-standard setup so off the shelf won't really work for me. I need to run just one line under the car from my Facet Fuel pump to my Filter King Fuel Regulator/ Filter. Then I just need to run a line to my Bike Carbs.
Should be simple enough I just wanted to see what diameter to get before I order it all also what adaptors people use as I don't want to use crappy clips, I want it all nice and solid and to look tidy.
Little_bro
isaidthephil
This is exactly what I'm looking for =) cheers mate
