Hi
I am replacing the dampers on a 1987 MK2 GTX. Having got the spring and damper retaining nut off I expected to find a simple damper inset to pull out. However I have found that the damper is an integral part of the strut and the strut seems to be the outer housing of the damper as the piston seals against it . I am hoping that the damper inserts you can get from GSF etc will just slot right in and replace this. can anyone help / advise?
Front Strut Damper replacement
- go-for-it1
Re: Front Strut Damper replacement
Yeah it just slots in. Tip- put some engine oil or leave some of the existing hydraulic damper oil in the strut before fitting the insert, this dissipates heat and stops any rattling between insert and strut
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
Ok thanks for the quick reply and the tip.That's a relief also won't have to clean all that old oil out:). Also GSF giving a 33% discount in November on all parts. So that's gonna help. Will replace the top mounts as well.
Try looking around for Bilstein B4's, these are a direct replacement for OE shocks and are the dogs bollox, and perfect if you ever want to uprate the springs to something like Eibach!
I have these and Eibach springs on my Storm and they are faultless.
Ring these people up, they were selling the B4's for about £35 a corner a while ago.
http://www.google.co.uk/url?url=http:// ... CvTyOLMfhg
Have to say I've gone right off bilsteins now, having had one snap that was only 3 months / 2k miles old
Tim_R
The B8s on my Saab and my 'rocco are still fine. Saabs have done 9k since fitting in April, I think you were unlucky Nate.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
Having searched about on tinternet, it would seem that certain cars have problems with them
