Fuel Tank Pipe Bore Size
Mark H
Post by Mark H »
Hi
Does anyone know the bore size of the metal pipe on the fuel tank were the rubber pipe fits ?
Mark
Mark
Alpine White
VW Scirocco GT2 (1991)
Membership Number 1296
Re: Fuel Tank Pipe Bore Size
Blueshark
Post by Blueshark »
Hi Mark,
Wait a few days and you can measure it yourself :P
Joost
ps. it is indeed 40mm.
Mark H
Post by Mark H »
Joost
Not the Filler neck size but the tank?
Saw your PM mate, cheers
Mark
Mark
Alpine White
Blueshark
Post by Blueshark »
Mark H wrote:Joost
Mark
Would be the same size, otherwise the hose won't fit on the neck and tank beeing it a straght hose.
Joost
chris_d66
Post by chris_d66 »
Tank inlet is
internal 38.66mm
External 40.20mm
Flange 42.10mm
The lower section of the fuel filler pipe is the same diameter of the tank inlet.
I have found you can use 38mm stainless exhaust pipe the link hose will grip the pipe but it is worth while running a step weld around the edge of the pipe which increases its diameter
Hope this helps
2001 A3 1.8t getting ready to be a donor
2003 Picasso dirty diesel
1995 Golf GTI 16V
1989 Scirocco GT undergoing restoration
1965 2A SWB Landy
Mark H
Post by Mark H »
Chris
Perfect, thanks
Mark
Mark
Alpine White
chris_d66
Post by chris_d66 »
Hi Mark
If you are considering making the filler pipe then I recon it may be worth looking into using 1 5/8 pipe which is 41.27mm diameter for the lower 45 90 45 degree sections. then adaptor to 57mm for the filler neck with a 16mm diameter tube just bellow the neck.
I made mine out of 38mm but the next will be 1" 5/8 for a snug fit on the link pipe.
Chris
1995 Golf GTI 16V
1965 2A SWB Landy
