Is my battery a goner?
Posted: Sun Jul 20, 2014 11:27 am
by Reverend Frog
Very cleverly left my lights on overnight. the car is not starting on the key (i just get the click from the starter solenoid), won't bump start and won't jump off my mum's Astra either.
is my nice new Bosch battery destined for a trip to the skip? or is there any way it can be saved?
PS I don't have a battery charger or anything
Re: Is my battery a goner?
Posted: Sun Jul 20, 2014 11:46 am
by bengould
If the battery is really flat it won't jump start straight away anyway. You'll have to leave it connected to another car with the engine running for at least 10 minutes to get some charge in your battery if you don't have a charger. Or buy/borrow/steal a charger and leave it on overnight.
You may have knackered it, but if it's a new battery I wouldn't give up on it just yet.
Ben.
Posted: Sun Jul 20, 2014 11:50 am
by Reverend Frog
bengould wrote:If the battery is really flat it won't jump start straight away anyway. You'll have to leave it connected to another car with the engine running for at least 10 minutes to get some charge in your battery if you don't have a charger. Or buy/borrow/steal a charger and leave it on overnight.
Ben.
it was connected to the astra for ten minutes or so, not a sausage
Posted: Sun Jul 20, 2014 11:54 am
Ring AA (other breakdown services are available) and they will do a proper battery test for you
Posted: Sun Jul 20, 2014 12:18 pm
by ianaudia4
If the battery is goosed then take it back to the place you bought it, Bosch batteries come with al least a 3 year warranty. (I would avoid saying you left your lights on though!)
Posted: Sun Jul 20, 2014 12:20 pm
by Reverend Frog
ianaudia4 wrote:If the battery is goosed then take it back to the place you bought it, Bosch batteries come with al least a 3 year warranty. (I would avoid saying you left your lights on though!)
haha, yeah, i think i'll be economical with the truth on that one...that was the one you fitted for me in Finchley
Posted: Sun Jul 20, 2014 12:29 pm
by marcus
While lead-acid batteries don't take kindly to being left discharged for long periods, just leaving your lights on overnight shouldn't have done any significant permanent damage, especially not if it's new. If you left it like that for a month it could be a different story.
Get yourself a battery charger (can't recommend having one of these highly enough), they're not expensive, eg this one from Argos and give it a full charge.
Posted: Sun Jul 20, 2014 1:30 pm
Just a thought, but how are you connecting the leads? Did they spark when you connected them? (you normally do get a bit of a spark)
Posted: Sun Jul 20, 2014 1:41 pm
by Reverend Frog
Nate wrote:Just a thought, but how are you connecting the leads? Did they spark when you connected them? (you normally do get a bit of a spark)
there was nothing
Red to + on good battery, then other end on + of my car
then black to - on the good battery, then the radiator bracket on my car (unpainted piece of bodywork as recommended)
any suggestions as to whether that was wrong?
Posted: Sun Jul 20, 2014 2:02 pm
by ianaudia4
Where did you buy it, ECP?
Overnight with side and tail lights shouldn't kill the battery but you never know!
Posted: Sun Jul 20, 2014 2:06 pm
by Reverend Frog
GSF Ian
Posted: Sun Jul 20, 2014 3:00 pm
by ianaudia4
GSF Ian
That's good then, there is a branch in NI I think?
Posted: Sun Jul 20, 2014 3:02 pm
by Reverend Frog
yeah, Belfast. Shut today of course
Posted: Sun Jul 20, 2014 3:17 pm
there was nothing
A flat battery will pull a fair bit of current when you connect it up to a good battery. When I was working roadside, we were told to always connect direct to the battery terminals when possible.
Probably what has happened is you have picked an earth point on the casualty car that is either aluminium and covered with a think layer of insulating corrosion, or something that just isn't earthed at all.
Try again, either just having the leads directly battery to battery, or have the -ve going to something like the alternator bracket or the main earth on the gearbox.
Connect up, you should see a little bit of sparky spark when you connect the last lead. Leave it sit for a few minutes, then start. Once running, switch on headlights and blower fan on both vehicles, then disconnect. This helps to prevent a big spike from the alternators.
Once disconnected, leave it running for 5 minutes or so, switch off and restart. Assuming it restarts ok, take for a drive of at least 15 minutes before switching off again. Should be fine
