Rear disc conversion using later type caliper
Posted: Mon Jul 14, 2014 2:59 pm
I've done a rear disc conversion. Having an issue with cables. The later style caliper (mk2/3/4) the cable come up through the bottom of the caliper so using the just caddys adapter sleeve the cable is too short. From reading this is also the case with the rocco 16v calipers. Has anyone done this and have a solution?
