It stopped on the way home from picking it up last weekend, doing about 70 on the M5 it just slowed down and then refused to start again. The RAC chap diagnosed it as a buggered coil, which seemed to be right as replacing the coil got it running again on Tuesday.
Decided to go for a spin this afternoon, only for the car to stall shortly after starting and idling for a bit, never to start again.
There appears to be fuel getting the carb and I'm pretty sure there is a spark as very occasionally it will run for a couple of seconds, then stall again.
I have replaced the battery, coil, HT leads, spark plugs, rotor arm and distributor cap and the situation is the same.
Any ideas why it won't start?
{EDIT} I am mildly concerned my engine might have lunched itself, although the fact that it has idled successfully since stopping on the motorway makes me think this is less likely. The car hasn't been run properly for some years, so I am worried about nasty things happening.
