Fuel Filler Neck no longer available
tim84storm
Post by tim84storm »
Hi
I emailed VW Classic Parts in Germany to enquire about the fuel filler neck 533201129D shown
http://shop.volkswagen-classic-parts.de ... utzen.html
and have received a reply saying "this part is not available any more".
Anybody know of an alternative - I've phoned VW Heritage but they want £377 !
scrumpyone
Re: Fuel Filler Neck no longer available
Post by scrumpyone »
Try contacting this guy directly:
peter.alt@vw-classicparts.de
Whenever I need any parts I e-mail him to ensure availability, price & delivery. He's really helpful.
The filler neck should be about 134euro
Dave
Register No:1110
'79 MK1 GLS (R.I.P.)
'91 MK2 GT2 (alive & kicking)
tim84storm
Hi Scrumpyone - will do - many thanks for your response.
Blueshark
Post by Blueshark »
The partnumber 533201129D is out of stock at the moment.
So Classic Parts is right at the moment.
Joost
ThomasD
Post by ThomasD »
Yes, its unfortunate - it is not clear if Classic will restock any time soon or not.
My local VW dealer can still get the 533201129C part. The "C" and "D" parts differ slightly. In my case (1984 Storm), the "C" part was actually the correct part. It is longer and uses the 1/4 turn twist on cap, rather than the screw-in cap.
The "C" part is about $263 in the States, or about 156GBP, so it is still expensive. The "D" part from Classic was less expensive. If you don't have any luck with Classic, you can check with your local dealer and see what they can do, or you can search the forums and see what other people are doing - modifying Mk1 Golf fuel necks, using plastic necks, etc.
Good luck!
Tom
Mk2 Scirocco Storm
Mk3 Golf GTI VR6
BMW e36 filler necks have been utilised previously, they're plastic and at least one member on here had made fit to a mk2 with gentle coaxing and a heat gun.
greenrocco92
Post by greenrocco92 »
Has anyone had any luck finding the 533-201-129C, I think that's the one I need (gt2 92) I can't find one anywhere.
Macc
Post by Macc »
As far as I know, Joost (Blueshark) can do the filler necks, its just the end piece thats a problem (that the cap goes onto) but im led to believe that if you lop yours off and send he'll attach it.
Could be wrong about all or some of the above but Blueshark will put you right im sure
1990 MK2 1.8 GTII Scirocco "Black Shuck"
joost can supply the cap its the pipe he said hes struggling to get the price down on last time i spoke with him
Blueshark
Post by Blueshark »
I have the endpiece where the filler cap fits on.
The pipe itself is the problem pricewise due to a bit of labour going into bending and a bit of streching and schrinking which is needed.
Looking for a company or some one to make it cheaper but no luck so far.
Joost
