EX engine oil leak at timing belt end
Posted: Sat May 24, 2014 10:45 am
by MacColl
It's an 8V carbed EX engine. I am aware that the cam cover can leak and the sump gasket but don't think its either. Could I have a leak at either of the oil seal rings at the cam or bottom end? I'll also mention a ticking noise from the timing belt that I get when the car is warmed up. I never figured out what it was?
Is this known to happen? easy to change top and bottom seals? best place to buy?
You can see oil at the bottom which is evident above above the sump..
Could it be coming from this oil seal or the lower Crankshaft one?..
Re: EX engine oil leak at timing belt end
Posted: Sat May 24, 2014 1:33 pm
by GTXTRA
Intermediate shaft oil seal is a usual cuplrit re 'where the hell is that leak coming from' - worth doing when changing cambelt as per this thread on mk1 golf forum
http://vwgolfmk1.org.uk/forum/index.php ... aft-seal_2
Posted: Sat May 24, 2014 11:11 pm
best way to trace an oil leak is first off, clean all the oil off. get some degreaser or carb cleaner and go nuts. take it for a short run afterwards and it will be much easier to see where it is coming from
Posted: Sun Jun 08, 2014 8:40 pm
by james butler
Another thing that can cause this is your rocker cover breather is blocked, especially the mesh bit built into the rocker cover.
Mine was leaking from the intermediate seal but when I come to change it the seal had actually been pushed out of the block by crankcase pressure. My rocker cover mesh was rammed with nasty gunk.
As Nate says tho change the seals and the timing belt together and while you have the rocker off clean out the mesh filter.
