Crazy speedometer/clocks
Posted: Thu May 15, 2014 6:10 pm
by scirocco-monkey
OK, The mileage clock in my Scirocco sometimes works and sometimes does not, I have changed the clocks and it's still the same. Is there anything I need to check or am I just unlucky to have to dodgy sets of clocks? Everything else works perfectly.
Cheers...Rich
Re: Crazy speedometer/clocks
Posted: Thu May 15, 2014 7:21 pm
by james butler
Check the speedo cable is connected properly if not that then I would get a new one.
Posted: Thu May 15, 2014 7:24 pm
by ianaudia4
Indeed, the cables can rust on the inside and stop turning!
Posted: Thu May 15, 2014 8:25 pm
by scirocco-monkey
Ahhh right, I thought since the actual speed and rev counter works fine the cable would be ok, It's only the mileometer thats playing up. Is it easy enough to change the cable or is it a pig of a job?
Posted: Thu May 15, 2014 9:27 pm
There used to be a how to page on repairing your Speedo when this happens. It's a common fault and a relatively easy fix
Posted: Thu May 15, 2014 9:48 pm
by scirocco-monkey
Looks like I will be ordering a new one then. Thanks for the help dudes
