Dash clock bulbs
pasenah
Dash clock bulbs
Post by pasenah »
Can the dash clock bulbs be replaced with brighter LEDs?
Blueshark
Re: Dash clock bulbs
Post by Blueshark »
pasenah wrote:Can the dash clock bulbs be replaced with brighter LEDs?
Of course, you just have to find the LEDs with the right voltage and fitting.
Or make something yourself if you can.
Joost
marcus
Post by marcus »
You don't usually get a choice of fitting with LEDs, typically there are two bare solid leads, one longer than the other to distinguish the anode (positive) from the cathode (negative).
Typical LED voltages are in the range 1.8 - 4V, red and yellow fall at the lower end, green in the middle and white at the upper end.
To avoid damage, you need to use a series resistor to limit the current ie if you connect a 12V supply to an LED with a 2V voltage drop it will burn out in moments.
1985 GTL 1.8
iroberts696
Post by iroberts696 »
Yes , I had some from ebay a couple of years back, there was even a choice of colour. Had to fit the wire ends of the leds into the bulb holders, its a pain getting the polarity right. Must admit the were disappointing, replaced with std bulbs after a couple of weeks.
You don't understand Newton's Third Law of Motion?
It's not rocket science, you know
