Lower Strut Brace
Posted: Fri Feb 21, 2014 4:41 pm
by crashbanggg
Am I right in thinking this strut brace will fit my Mk2?:
http://www.ebay.co.uk/itm/OMP-FRONT-LOW ... 2c7bc668c5
If so, what/ would I need anything with it to fit it or does it use pre existing bolts?
Chris
Re: Lower Strut Brace
Posted: Fri Feb 21, 2014 4:59 pm
by monzajake
Thats the one. It should come with replacement bolts
Posted: Fri Feb 21, 2014 5:08 pm
by crashbanggg
Thanks!
Posted: Fri Feb 21, 2014 6:37 pm
by DJPremier
I have of of these on my Mk2. I have the anthracite version. It did not come with new bolts, but the tubular fitting points are not so thick that you need new longer bolts. Works fine with the originals. Such a worthwhile upgrade though..
Dave V
Posted: Sat Feb 22, 2014 12:32 pm
by marcus
I remember Mr Funk telling me a lower strut brace transforms the handling but I neglected to ask exactly where it fits, can anyone point me in the direction of a pic or diagram?
Posted: Sat Feb 22, 2014 7:27 pm
by bengould
marcus wrote:I remember Mr Funk telling me a lower strut brace transforms the handling but I neglected to ask exactly where it fits, can anyone point me in the direction of a pic or diagram?
Between the front of the wishbones. Mounts using the bolt that goes through the front wishbone bush.
Ben
Posted: Sun Feb 23, 2014 3:26 am
by mr.brown
I've just shared a link to one on the Facebook page.
Posted: Sun Feb 23, 2014 9:27 am
by Mr Funk
Saw that this morning. Very nice
Posted: Wed Feb 26, 2014 2:26 pm
by crashbanggg
Success!
Posted: Wed Feb 26, 2014 9:21 pm
Looks close to the exhaust etc from the angle of the photo?
Posted: Wed Feb 26, 2014 10:16 pm
by go-for-it1
Did the wishbones move out of alignment when you took the bolts out, and did you jack one or both sides at the same time when you fitted it? Just need to know what I am up against when I fit mine.
Posted: Thu Feb 27, 2014 12:19 pm
by crashbanggg
mark1gls wrote:Looks close to the exhaust etc from the angle of the photo?
I think that's just the angle of the photo, seems to be well clear of anything in reality :)
go-for-it1 wrote:Did the wishbones move out of alignment when you took the bolts out, and did you jack one or both sides at the same time when you fitted it? Just need to know what I am up against when I fit mine.
Although someone will probably come along and tell me I did it wrong, I just jacked it on one side and had no problem with the wishbones moving, simplest job I've done on the car I think!
Posted: Thu Feb 27, 2014 5:55 pm
just a thought - you are *supposed* to tighten those bolts with the weight of the car on the wheels. in reality, doing that is a pain in the hole
Posted: Thu Feb 27, 2014 11:05 pm
by go-for-it1
Although someone will probably come along and tell me I did it wrong, I just jacked it on one side and had no problem with the wishbones moving, simplest job I've done on the car I think![/quote]
Thanks matey.
Posted: Sun Mar 16, 2014 9:05 pm
by Nathan
Thanks for the tips in this thread.
Finally got round to fitting mine this evening and boy, roundabouts sure are fun now!
